Can This Small Wall Be Taken Out? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-07-2016, 01:53 PM   #16
Rewards Points: 86
SO... I hadn't actually seen what my husband was talking about. We went there and I took some pictures. WHYYYYY?!?! Why would they just yank on the wood like that?!?! If it's not moving, STOP. THINK. Dear goodness. Only afterwards did they think to use the Sawzall. So there are several spots that are saved, thank goodness. But now this just adds more work and materials on our plate. Ugh.
Here is what my husband was trying to describe
Close-up.
Another close-up.
Here you can see the spikes that were driven through from the top.
What would be the best way to go about this? Would we need to get someone to go in the attic, move all the insulation, and assess the damage? How far back would you think we need to cut the drywall? And can we just replace sections of this strapping? Or would we need to replace the entire piece, each piece?
Ohh... what a mess... I wish my husband didn't leave for pizza.
mrssp is offline   Reply With Quote
Old 02-09-2016, 02:16 AM   #17
Rewards Points: 1,036
Originally Posted by mrssp View Post
SO... I hadn't actually seen what my husband was talking about. We went there and I took some pictures. WHYYYYY?!?! Why would they just yank on the wood like that?!?! If it's not moving, STOP. THINK. Dear goodness. Only afterwards did they think to use the Sawzall. So there are several spots that are saved, thank goodness. But now this just adds more work and materHere you can see the spikes that were driven through from the top.
I dont think anything important was damaged framing wise the blocks going perpendicular to the way the wall was were just to hold the wall straight since you dont have a wall any more they serve no purpose.
the 2 long 2x4s running parallel with the wall you took out are just nailed on top of the wall so you have something to nail the sheetrock to. so they are obsolete as well.
as long the perpendicular boards i can see are Not trusses you are fine just check that none of them are trusses and you will be ok.
if it is the truss let me know i have the repair detail somewhere on my computer i will post it if needed.
Mingledtrash is offline   Reply With Quote
Old 02-15-2016, 09:02 PM   #18
Registered User
Rewards Points: 526
Take a pic. above the wall where the wood is split as you said the wall ran E-W and the trusses run N-S. If so that may be furring strips of wood 16"on center perpendicular to the trusses 24" on center, please verify...
Gary
Unsure of small retaining wall materials. MurphyMan Concrete, Stone & Masonry 4 09-30-2013 01:31 PM
How to Square a Wall or Layout for a Foundation BigJim How To Guides 2 01-31-2013 10:48 PM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 01:26 PM
In The Process Of Building My Very First Small Retaining Wall ricksample Landscaping & Lawn Care 3 03-19-2010 10:19 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
