Can I Enclose My Porch? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-08-2010, 07:30 PM   #1
Can I enclose my porch?
Hi everyone, let me try to explain the best I can.
On one end of my house there use to be a carport. The people who owned the house before me took that carport and on one half they made a "sun room" well thats what they called it. It is heated and cooled and has 3 long windows on each of the 3 walls. On the other side they made a porch. However, on the porch side the floor is concrete and there are 4 post holding that side of the roof. ( the roof covers the whole space, both sun room and porch. Now the post are not bolted into the concrete they sit on these metal things (sorry I have no idea what you call all of this) Anyways, what I would like to do is make this whole space one big room. Which would mean closing in two wall, taking the window out of the wall that now divides them and either knocking that wall out or making a large walkway. My question is, can it be done?
I'm sorry if this post is confusing.
huffdaddysgirl is offline   Reply With Quote
Old 10-08-2010, 07:44 PM   #2
Rewards Points: 5,348
Post some photos.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
huffdaddysgirl (10-08-2010)
Old 10-08-2010, 07:51 PM   #3
Ok Ron, I will in the morning. To dark now to really be able to see anything.
Old 10-09-2010, 12:24 PM   #4
Yes, it can be done! Just need pics
mrgins is offline   Reply With Quote
Old 10-10-2010, 10:06 AM   #5
Hope this works I wasn't sure how to upload a picture on this site.
Old 10-10-2010, 10:13 AM   #6
Civil Engineer
Rewards Points: 5,246
You need to start by having a chat with the building inspector. Especially if the previous owners "forgot" to get a permit for the work they did. Enclosing space always requires a permit, unless you live in the far boonies where the buses don't go. But of course you can enclose space, simply requires framing, finishing, and possibly electrical and plumbing.
Old 10-10-2010, 10:25 AM   #7
Thank You! It would not surprise me if the previous owners didn't have permits. I've found that they did a lot of "updates" that they cut corners on.
Old 10-10-2010, 10:59 AM   #8
That looks like the floor is at or close to grade level. I don't know where you live, but you might consider an insulated slab
Old 10-10-2010, 11:00 AM   #9
We are in North Carolina.
Old 10-10-2010, 12:50 PM   #10
Oops! Didn't read your initial post that states there already is a slab. Shouldn't be a problem if you consult the inspector first
Old 10-10-2010, 02:50 PM   #11
Registered User
Rewards Points: 526
The existing slab appears to drop 6" on the outside edge when lining up the railing with the roof line in the first picture. As it was a carport slab there are not any thickened edges around the slab perimeter to hold up the walls as required by current code. In your State the heating degree days vary from 0-4000 annually to require 0/2’ of foam insulation under the slab at exterior perimeter, depending on location. A vapor barrier under the slab with a heated space will also be required if under the IRC minimum safety codes. So with the existing slope, I would contact the B.D. and pour a new slab, up to today’s Code. Then you would have the new square footage on your house’s personal record with the County for higher resale value and H.O. Insurance coverage.
Gary
How to Winterize Porch subdude Remodeling 0 02-04-2010 10:00 PM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 07:54 AM
Help - I need to enclose a porch DDRowe Remodeling 5 11-30-2006 12:43 PM
PORCH: To Enclose or not to Enclose... singforsupper Building & Construction 2 08-05-2005 09:46 PM
Framing in New Windows to enclose a porch DDRowe Building & Construction 2 05-25-2005 08:05 PM
