Can I Demo These Steps With This Drill? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-09-2010, 12:58 PM   #16
I have gas!
Clutchcargo's Avatar
Rewards Points: 2,010
Do you actually need to remove these steps? I've seen abandoned stairs under decks on many houses. Then you wouldn't have to pay for disposal.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 03-09-2010, 01:09 PM   #17
Rewards Points: 3,130
Trust me, unless the steps really are concrete-coated block, your drill won't possibly do the job before self destructing. At 6 amps and less than $100, it's basically a toy for the gentleman DIYer. It'd probably overhead mixing thinset.
Old 03-09-2010, 01:22 PM   #18
Rewards Points: 278
Yes because I don't want to be able to see them when the deck is done.
jpearson311 is offline   Reply With Quote
Old 03-09-2010, 03:10 PM   #19
Rewards Points: 502
I'd rent an electric jack hammer and go to town on them. For about $40 you could save time compared to what your original plan was.
http://www.sunbeltrentals.com/Equipm...0120&catid=s44
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
Re-staining inside steps saggdevil Painting 10 09-20-2009 06:40 PM
Determining correct drill key MRTIGRE General DIY Discussions 3 06-04-2009 01:58 PM
