Can I Convert My Shed Roof To A Gambrel Roof? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-29-2016, 08:56 AM   #1
Rewards Points: 24
Can I convert my shed roof to a gambrel roof?
I've got a 10x12 wood shed that's currently seeing a good amount of damage to the roof, floor and lower T1-11 siding due to water damage. As I look into my options to repair various portions of it, I was wondering if it's possible to covert the roof to a gambrel style to gain some more space.
Currently, the front wall is about 7' high and the roof slopes down to a lower wall on the back side (about 6 feet high). My question/concern is, can I frame up the additional foot or so, attach on top of the back wall to level things, and then put the gambrel on top? I'm trying to avoid needing to remove and reframe the entire back wall of the shed, but will obviously do so if structurally the proposed design won't suffice.
Quick sketch of what I'm considering is attached below. Thanks!
PSUlion01 is offline   Reply With Quote
Old 06-29-2016, 09:16 AM   #2
Rewards Points: 18,350
Re: Can I convert my shed roof to a gambrel roof?
Can it be done yes, is it worth doing on a shed with rotting siding and failing floor?
Most common cause for these failures is the sheds to close to grade and no roof over hangs.
If you do go with the new style roof I'd suggest having trusses made for storage, they will have a wider bottom cord.
Old 06-29-2016, 09:18 AM   #3
landfillwizard's Avatar
Rewards Points: 620
pole barn or studded walls? 2X4 or 2X6?
landfillwizard is offline   Reply With Quote
Old 06-29-2016, 10:00 AM   #4
Rewards Points: 24
Thanks for the quick replies. A little more detail.
Shed has studded 2x4 walls. While there's damage, it's not nearly enough to scrap the shed and replace. A few hundred bucks and I'm good as new vs $2500 to replace it.
As for the water damage, a few things:
1) Shed was previously under a lot of trees that kept the area damp (no sun). In addition, leaves would collect around the base and hold a lot of water that led to floor and bottom wall damage.
2) Roof damage stemmed from tree branches that fell and damaged shingles and sheathing. Water damage ensued.
3) Current roof has slight overhangs, but again the location under the once-there trees amplified the water issues.
4) I plan to raise the shed a few inches when doing the repairs, in addition to rebuilding the pavers that surround the shed, and will make sure the drainage issues are resolved.
Thanks again!
Here's a pic for reference:
Old 06-29-2016, 06:22 PM   #5
Rewards Points: 24
Thanks. So by wider bottom chord, are you basically referring to the joist that spans the walls and that would support the "loft" area? I would assume just check he span tables and use 2x6 or 2x8, though the weight up there would be kept light.
Shed roof pitch question Kevin P. Building & Construction 12 05-17-2013 09:12 PM
8x12 Gable Shed - Roof Help wguttrid Roofing/Siding 9 05-17-2013 08:02 AM
add shed roof to gable roof lucy1 Roofing/Siding 0 10-30-2011 09:31 PM
Shed roof construction questions wombosi Building & Construction 3 10-28-2011 11:01 PM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 08:28 AM
