Building A Tigerwood Deck Over A Flat Rubber Porch Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-21-2015, 05:50 AM   #1
Rewards Points: 68
Building a tigerwood deck over a flat rubber porch roof
(I wasn't sure if this should go in the roofing section or where, so figured this forum kind of covered it all)
I have two flat (or actually just slightly pitched) 2nd floor porches that are currently covered with black rubber roofs. One is approximately 10 feet x 14 feet and has been patched numerous times (I just bought the home this year) and that one also came with a stack of well worn deck panels made out of regular treated lumber that fit over the porch/roof space to form a deck over the black rubber roof.
The second porch is somewhat smaller, approximately 8 feet x 12 feet and didn't have any old deck panels that came with it and that rubber roof is in somewhat better shape, but if I'd have someone come and replace the other rubber roof, I figure I'd have them both redone at the same time.
What I'd like to do is to build new decking panels for both porches, they are both very useable and I know that rubber roofs aren't the best to have people walking all over on a regular basis, but I just want to make sure that what I build doesn't damage the rubber roof at all.
Since the spaces aren't that large and its a nice, older home, I'd like to use Tigerwood for the decking and had planned on using regular treated lumber for the joists under the decking, with the joists running in the right direction so as not to screw up the slight pitch for the drainage.
I would think this should work out fine and would construct it in sections, but then have it screwed together to seem more like one big, continuous deck, but which could be fairly easily taken apart back into sections in case any access to the rubber roof is needed.
Do you think it might be a smart idea to line the undersides of the joists that would be coming into contact with the rubber roof with some heavy felt or anything else, just to reduce any wear and tear on the rubber roofing? Any other suggestions? Thanks!!!
BT5150 is offline   Reply With Quote
Old 07-21-2015, 07:33 AM   #2
Low Slope Roofing
Rewards Points: 114
It's done all the time, attach a properly flashed ledger to the house, and the rest of the deck floats on the EPDM. You are correct you want to uses some kind of protection, when we do them I leave extra reinforced EPDM for the deck builders to use. Use screws so that it can be taken apart. Also replacing the roofing before you do this is a good idea, plus do some kind of water test before the deck is built.
1985gt is offline   Reply With Quote
The Following User Says Thank You to 1985gt For This Useful Post:
Windows on Wash (07-22-2015)
Old 07-21-2015, 09:54 AM   #3
Rewards Points: 1,476
Be sure that the structure can handle it. It is close to twice as heavy as basic pine pt.
Ron
O
ront02769 is offline   Reply With Quote
Old 07-21-2015, 05:19 PM   #4
Rewards Points: 8,538
I know you didn't ask about choice of decking material, but if you are looking for exotic hardwood decking, I would suggest ipe. Nothing prettier than fresh tigerwood, but my experience is that ipe holds it color much better than tigerwood.
SPS-1 is offline   Reply With Quote
Old 07-21-2015, 05:57 PM   #5
Rewards Points: 144
I know it's"done all the time" but it does not make it right.Why do you think so many of these roof/ decks fail???
mako1 is offline   Reply With Quote
Old 07-21-2015, 06:14 PM   #6
Low Slope Roofing
Rewards Points: 114
Improper installation. Mainly poor details.
We've done them that have lasted 20 + years, with all kinds of material over the top. Wood, pavers, stamped concrete.
Here's one sorry no finished pictures with the 24"X 24" pavers.
1/4" per foot tapered insulation, 1/2" densdeck over that. 60 mil EPDM with 6" seams.
Another one we did for the same builder, 60 Mil EPDM glued to the plywood 4" of fancy concrete over the top of it. The upper level was a wood deck, again sorry no pictures of the finish of that one.
Just because you don't know how to do it or know anyone who can doesn't mean it can not be done....
BT5150 (07-29-2015)
Old 07-21-2015, 06:18 PM   #7
Low Slope Roofing
Rewards Points: 114
This is what happens when you try and do a non free floating deck. Flashing the posts is hard.
Building a tigerwood deck over a flat rubber porch roof-bad-posts.jpg   Building a tigerwood deck over a flat rubber porch roof-no-posts.jpg
BT5150 (07-29-2015)
Old 07-21-2015, 11:06 PM   #8
Msradell's Avatar
Rewards Points: 912
What the heck is that HVAC duct doing running outside of the structure like that? Was (is) a deck built over it?
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 07-22-2015, 06:17 AM   #9
Rewards Points: 68
Thanks for the responses everyone, an interesting mix of ideas and opinions! Also interesting that someone mentioned the actual weight of the VERY dense Tigerwood, which I first learned of while doing some more research today on working with it and they suggested using all carbide tipped blades I believe and that's when I figured out just how heavy it is. This is the MOST well built home I've ever owned, first floor for instance is poured concrete over steel trusses, 2nd floor uses 2x12;s for joists!
I'll keep you updated, first step is getting the current rubber roof replaced!
Old 07-22-2015, 06:51 AM   #10
Low Slope Roofing
Rewards Points: 114
IIRC it was a drier vent duct. Yes a deck was put over it by someone else.
The devil is in the details as far as the roofing goes. It gets really expensive when you have to remove decking when you have a leak that needs patched.
Old 07-22-2015, 08:55 AM   #11
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 6,764
We see plenty of floating deck on commercial properties where large condo buildings will have a deck/entertainment area on the roof. Pretty commonplace in this area and they can do quite well if their engineered properly from the outset.
The Following User Says Thank You to Windows on Wash For This Useful Post:
1985gt (07-22-2015)
Old 07-29-2015, 11:53 PM   #12
Rewards Points: 68
Well I'm moving into the design phase now, I am going to definitely do it and I think I have a few pics of the existing porches, I'll take a look after this and post them if I do, if not I'll snap a few tomorrow (with a real camera) and post them then. As I mentioned, its the best built home I've ever torn into (I've torn into a fair number of mostly older homes here in the Milwaukee area, where we have a good number of older homes, as well as a lot of new ones, mostly in the burbs) This place was built in the late 30s, when I've seen many smaller older homes here using 2x8s and even 2x6s in some cases for floor joists but this place has poured concrete over steel trusses on the first floor and 2x12s between the first and 2nd floors. So, I'm not too concerned about the extra weight of using something like Tigerwood for the decking.
I talked to the company that built the decking for the rooftop area at my brother's restaurant here, which used Ipe wood and they used regular pressure treated lumber running perpendicular obviously for the structure under the Tigerwood and since its not that large of an area and the pressure treat wood is comparatively pretty reasonable to the Tigerwood, so I don't mind if the spacing isn't too wide for the pressure treat and I see that most dealers sell it in (as far as the 6" wide planks go) both 1" thick (nominal size I assume so really 3/4" thick) and 5/4 x 6 planks but I'm wondering if its worth the extra expense for the 5/4 x 6 planks or if I'll be fine with the 1 x 6s, for what won't be a regularly used deck, since this is a deck off of a bedroom, not a backyard deck or something like that. Also, as far as the spacing for the perpendicular structural boards underneath, I was thinking maybe 12" or 10", not ure any ideas?
Flat Roof (my porch) is leaking in the corner SpaceCoast Roofing/Siding 6 04-22-2013 10:27 AM
building deck on new tpo roof. lkheisler86 Roofing/Siding 5 11-08-2011 10:51 AM
New Rubber Flat Roof w Ponding Problems Shifter Roofing/Siding 8 10-20-2010 11:58 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
flat roof under deck??? Jeremy Hillary Boob, PhD Roofing/Siding 3 05-05-2009 08:20 AM
