Building A Shed. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-11-2010, 08:02 AM   #1
Building a shed.
Hi again.
I've been trying to price material to build this shed here and with school and baby things just get lost in the shuffle.
I was dead set on doing it with steel to get a feel for how it works but I want to elevate the shed and be able to put a rider mower in it. So I don't know how the floor joisting would work with the joist and channel taking that kind of force when the mower is driven in.
So my question is which is the more cost effective way to go, wood or steel?
Thanks in advance
Axe McGee is offline   Reply With Quote
Old 02-11-2010, 10:31 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 586
Ayuh,... I prefer a concrete slab,+ a Steel building...
1 I've built is a Steel building on a stone pad... Only because it's over/ atop the sewer line...
Old 02-11-2010, 11:10 AM   #3
Rewards Points: 5,348
Steel buildings used as sheds would probably be sat on a concrete pad or a wood platform. These structures don't generally have steel joists for support.
Ron
Old 02-11-2010, 11:31 AM   #4
Thanks that's what I was thinking.
I will go with the standard wood shed then and then steel garage on slab.
Old 02-11-2010, 07:48 PM   #5
Jeff McDonald 416 618-147
WestEndReno's Avatar
when you figure out the cost of materials, can you let me know? I'm planning the same shed in the spring.
thanks,
WestEndReno is offline   Reply With Quote
Old 02-12-2010, 05:50 AM   #6
will do, I got plans for a 16x20 from http://www.theshedplans.com/ $15 and they give you a great mat list and detailed plans how to build.
building a shed SirVisioneer Building & Construction 1 01-27-2009 07:25 PM
Morning Pilgrims! Greenhorn looking for answers! - Need help building a Shed bazzbozz Building & Construction 3 11-11-2008 08:36 AM
Building rafters for small shed simonb Roofing/Siding 4 07-15-2008 12:32 PM
Building a shed, need help with pouring slab / fill ssybert Building & Construction 5 06-12-2008 06:19 AM
building a shed boddah Building & Construction 11 03-21-2008 04:35 PM
