DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Building & Construction (https://www.diychatroom.com/f19/)
-   -   Building roof soffits? (https://www.diychatroom.com/f19/building-roof-soffits-164782/)
jfharper 11-26-2012 02:12 PM
Got an older house and would like to cover the exposed eaves and rakes with soffits to help with cleanup in the future, i.e. cobwebs and keep birds from pecking holes. I was wondering what material to use and what nail size/nailer? Could someone help me a bit with a little guidence? Thanks.
kwikfishron 11-26-2012 04:11 PM
199 Attachment(s)
Your options are couple styles of wood, vinyl, aluminum or fiber cement.
Vinyl and aluminum you don’t have to paint but don’t always look right on some homes.
How there installed varies some depending what type of siding and fascia set up you have now.
Posting a couple of pictures of your house would help to be able to tell you what exactly needs to be done for your particular situation.
hand drive 11-26-2012 09:52 PM
typical soffit material is 3/8 BC or AC plywood but there are many different materials as well even tongue and groove soffit. You can either have a leveled soffit that requires added framing or follow the rafter roof pitch and attach underneath the rafters with the soffit material.
Gary in WA 11-26-2012 11:23 PM
Good time to add soffit venting usually not found on older, exposed eaves, Use continuous angled louvers, screened, right next to the fascia board for optimum air-flow. The block venting notches/holes should leave most of it intact for structural strength.
Gary
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
