Building An Outdoor Fireplace In Tennessee - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-26-2011, 06:31 AM   #1
Building an outdoor fireplace in Tennessee
Putting in a FireRock fireplace & wanted to know what kind of foundation I need for it. How deep does it need to be? What kind of rebar, etc. The kit is 2200 lbs (not including the rock veneer) & 85" high. I also plan to build a cinder block base (2 block high) to raise the height of the fireplace. Never done anything like this before. Feel okay about everything from the fireplace assembly on, but just need advice on making the foundation.
McFamilyMan is offline   Reply With Quote
Old 11-27-2011, 09:59 AM   #2
Remodeler
Location: formerly from Kansas City but now reside in Falls City NE.
Most times on foundations, you must go at least 3ft deep because of freezline depending on where you live. Living in Tenn. that should be plenty. That being said, line out with paint or string where you need 2 dig (make sure no lines underneath) and dig a 1ft wide 3ft deep trench. If you are using cender blocks, drive 5 ft rebar stakes every 8 to 12 inchs into ground about a foot deep so they stick up out of hole about a foot. Pour concrete about 3 inchs below ground level. If you can make this level, putting on blocks will be alot easier! Good luck, hope I could help!
DYNAMIC DEEZLE is offline   Reply With Quote
Old 11-27-2011, 03:21 PM   #3
Concrete & Masonry
Rewards Points: 464
The bottom of footing should be below the frostline, if there is any in your area of Tennessee. After that, an 8" thick footing should be substantial enough, with a few 1/2" rebar going each direction. This is all subject to the soil conditions though........
jomama45 is online now   Reply With Quote
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
Effect of Heat Load of Tenants on a Commercial Building mphoenix HVAC 1 04-20-2011 04:59 AM
Siding on utility building Angela3511 Building & Construction 5 04-18-2011 08:28 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
