Building Doors For Shed/barn - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-25-2014, 10:19 PM   #1
Building doors for shed/barn
How do you guys build your doors for your sheds/barns? do you build a jam and hang the door after the framing is complete as you would in a regular house, or do you just hang the door directly in the rough opening and attach your door stop to the RO itself?
I'm building a barn, and it's going to have a double door in the front (~8'x8') and a regular door on each side.
ligyron is offline   Reply With Quote
Old 06-26-2014, 08:42 AM   #2
Rewards Points: 144
You want to build a jamb for the door.This give you room between the jamb and framing to level and plumb the door.
mako1 is offline   Reply With Quote
Old 06-26-2014, 09:24 AM   #3
Rewards Points: 18,230
Barns and sheds almost never have jambs, just the rough framing left exposed.
Depends a lot on what type siding your planning on when deciding how the doors hung.
Biggest mistake I see is not using three hinge's, and using to small a hinge.
If there going to be made out of something like T-111 consider making it a flush mount door and do not have the 1 X trim on the outside of the door frame and the exposed cross bucks on the door.
They look nice for a while but it's always the first place it's going to start rotting because the wood sticking out acts like a ledge to hold water.
Old 06-26-2014, 10:10 AM   #4
landfillwizard's Avatar
Rewards Points: 618
Is your barn stick built or a pole barn? What kind of siding? As joe said use 3 heavy duty hinges.
landfillwizard is offline   Reply With Quote
Old 06-26-2014, 11:38 AM   #5
Rewards Points: 144
I have done as Joe said,in the past ,and hinged directly to the framing.You post says "Barn/shed" which could be a lot of things.It all depends on the footing,foundation or whatever the structure is sitting on.These structures settle.When they do the doors start do bind.That's why I use jambs.When the structure settles and the doors bind it's a simple matter to readjust the jamb if this happens.It does not always happen but I still like the jamb and it makes it easier to trim out if you want to.
Old 06-26-2014, 12:40 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 492
Why not use sliding barn doors like in the link below?
http://www.bing.com/images/search?q=...on&FORM=RSRIMG
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 06-26-2014, 12:43 PM   #7
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,470
I'm trying to make my new shed match up with the garage it's attached to.
Since the garage has an OH door which sets back from the face about 8" --and I happened to have a couple of 2x8's handy when I thought about this-- I used them as the inboard jack for the (72" clear) shed door header. (link to thread with pics)
I plan to add a 2x4 to the face of that 2x8 (and block/support it all well), run that down to the concrete, and then triple hinge a pair of 36" home built doors. It should work out OK.
Until I change my mind again the doors will be a 2x4 frame laid sideways with a veneer of the same siding the walls get on top of that --and probably some rubber weatherstripping at the edges.
More pics to follow.
Old 06-29-2014, 01:56 PM   #8
Barn doors are such a cool look!
OurBuild is offline   Reply With Quote
Ideas for building custom bifold doors? crashley1784 Carpentry 1 02-18-2010 03:49 PM
Do Floor Installers Usually NOT Trim Doors? thebigsee Flooring 20 11-22-2009 10:14 AM
Building code for Bedroom Doors nik2009 Carpentry 3 05-04-2009 08:22 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 08:19 PM
