Building A Covered Porch For A Sauna - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By pckeen
  • 1 Post By pckeen
Old 08-30-2017, 12:22 AM   #1
Building a Covered Porch for a Sauna
I'm planning to build a 13x8 Sauna on a concrete pad. I want to add, on the lake side of the Sauna, a 4' covered porch. The attached jpeg link shows the design.
My plan is to support the covered porch using three 13' 2 x 10 laminated beams, two of which would be mounted on a 2x4 framed wall at either end. The third beam will be a ridge beam for the roof.
What are your views - good design, or should I rethink my approach?
The beams will actually be cantilevered, with a 1' overhang at the back, and a 4' overhang at the front. My original plan was to build this without a triangle support, but I am concerned about whether the roof can bear the snow load. I'm also concerned about whether I need a tension tie between the two cantilevered beam, as I assume there will be outward pressure on the beams.
Building a Covered Porch for a Sauna-exterior-plan-long-side-towards-lake.jpg
alozcarney likes this.
pckeen is offline   Reply With Quote
Old 08-30-2017, 01:39 AM   #2
retired framer
Rewards Points: 6,228
Re: Building a Covered Porch for a Sauna
Looks good...............
Old 08-30-2017, 08:33 AM   #3
Rewards Points: 8,142
LOL, saw your intro and had to laugh that the sauna had to come first.
With the sheathing on in your picture we can't see what the framing looks like behind it, like what is behind that diagonal coming down from the ridge beam?
An 8' span for the ridge beam might need some cross ties, which may be there in the design.
Check to be sure you can build towards the water, there are often setback requirements, mine vary from 100' to 300' and they have aerial photos to keep track of any new structures that pop up where they shouldn't, or trees cut or gravel moves, or rocks in the water moved, ya they watch everything up here.
Bud
Bud9051 is online now   Reply With Quote
Old 08-30-2017, 08:40 AM   #4
Thanks. If I dont build it first, I'll never build it. Inside the end walls will be diagonal supports, slotted in between the 16 inch on center studs. In the middle, no diagonal supports.
Sent from my SM-G920W8 using Tapatalk
Old 09-13-2017, 11:54 PM   #5
Well, the concrete pad for the Sauna is in, and my framing materials are being delivered tomorrow. Construction starts tomorrow evening.
Nealtw likes this.
Building a tigerwood deck over a flat rubber porch roof BT5150 Building & Construction 11 07-29-2015 11:53 PM
Covered Porch contessor Building & Construction 10 07-29-2014 07:58 PM
tile on an outdoor, covered porch (first post!) US expat Tiling, ceramics, marble 17 09-21-2013 12:44 PM
Covered gable porch overhead beam design Gunn317 Building & Construction 9 07-06-2013 10:31 AM
building a roof over my porch.. Dame130 Building & Construction 4 09-20-2012 02:44 PM
