Building BIG Chicken Coupe. - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 3 Post By rjniles
Old 04-12-2018, 05:07 AM   #1
Building BIG chicken coupe.
Hello all. First time posting. I was seeking advice on the roofing problem I'm having with my chicken coupe build. The size of this thing is L:25ft W:9ft 6in D 4ft. I am having issues with the roof. Have decided to leave little over half of the roof open (as in no would coverings) and use chicken wire to go over the top of it. Few questions. First is the size just to big to be practical? Second. Should I use something more then just the chicken wire? (Wire is 20ga 1in gaps) if needed I can take pictures. Any help would be greatly appreciated. Thanks
DizzyDizz is offline   Reply With Quote
Old 04-12-2018, 05:41 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,338
Re: Building BIG chicken coupe.
Pictures always help. How many chickens do you propose to raise? That will determine the size of the coup. The open roof area is fine as they need sunshine and like to bask in the warmth. Have you made provisions for water and food that makes it easy for you to handle? How about laying areas. They like their privacy. How are you treating the base? Will it be secure against the ground so animals can't get in to kill your chickens?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 04-12-2018, 06:19 AM   #3
retired painter
Rewards Points: 1,830
As Larry asked, how many chickens? I painted the roof on some coops [commercial] back in the 70s that were a 1/4 mile long. I'd make the actual coop part about a quarter of the overall size with some of the 'open' area roofed.
mark sr is offline   Reply With Quote
Old 04-12-2018, 07:24 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 224
Are your chickens taking your custom designed coupe to a car show?
Could not resist
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 04-12-2018, 10:17 AM   #5
The first 2 pictures are if the current homes for them. The 3rd is of the upright posts. 4th one is of the inside. There are lots of holes in the the floor of this. I was planning on taking dirt from our old horse pins and using it to fill the wholes and level it out a bit. Also was planning on putting current homes inside the new one. This "new one" was an old dog kennel but have since gotten moved to a better location.
Building BIG chicken coupe.-15235417151181149297965_1523541740334.jpg   Building BIG chicken coupe.-15235417746181493712454_1523541785107.jpg   Building BIG chicken coupe.-1523541954327251087587_1523541993637.jpg   Building BIG chicken coupe.-15235421725221542992059_1523542194304.jpg   Building BIG chicken coupe.-1523542387217172802578_1523542395060.jpg
Old 04-12-2018, 05:18 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 262
Ayuh,.... Pictures help, Alot,....
I'd think, to cover the far open area, yer gonna need a ridge pole, or some sorta support for the chicken wire,.....
The wire screen will Sag, Badly without some ridged supports across such a wide span,....
Lighter wire is better, less weight to support,...
Is the little chicken house gonna be under the roof, or out under the wire,..??
If out under the screen, it can be put to use, supportin' the overhead wire,....
Chicken Coop - Building Idea from recyceld material jardinier Project Showcase 6 07-21-2015 05:02 PM
Excessive flexing in building, tiny house AKTroy Building & Construction 23 07-11-2015 06:02 PM
Building a Chicken Coop Run mrrr0809 General DIY Discussions 4 05-28-2015 07:27 AM
Building house from scratch - Use 2x4 as Exterior wall? matt889 Building & Construction 19 01-26-2015 09:13 AM
Siding on utility building Angela3511 Building & Construction 5 04-18-2011 08:28 PM
