Building Addition - Crawl Space - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-05-2015, 10:12 AM   #1
Rewards Points: 56
I am building a small addition to the back of my house in Ontario.
Excuse the crude drawing (best I could come up with).
I am interested in finding out how to insulate and protect the crawl space.
This space will have sides(not sure if its going to be lattice or PT boards - #2 on drawing).
Either way,it will be partially exposed to the elements.
In the photo attached, it shows the insulation I intend to use between the
16" centre joists. Covered with Comfortboard (#1 on my drawing).
There would be vapour barrier on top of the joists,under the T&G sub floor)
Im not sure if I should then cover the Comfortboard with thin PT plywood or perhaps Aluminum soffit ?
I then want to make sure I can seal all the gaps and spaces (to prevent mice infiltration etc). Suggested method ?
Is there any point in covering the crushed stone ground (#3 on drawing) with Poly sheet ?(or is this only beneficial in an enclosed,conditioned space?)
Any benefit to cover the 6"x6" posts and 2"x10"(x3) beams with Comfortboard and PT plywood ? (to further prevent transference of cold)?
Any assistance would be appreciated.
wee-haggis is offline   Reply With Quote
Old 03-05-2015, 05:40 PM   #2
Rewards Points: 18,118
In your area I'd be doing footings and a real foundation, not just building on post.
Far easier to keep the floors warm without the wind and additional exposure to the outside.
No 2X"s or 5/4 are rated for direct ground contact.
Old 03-05-2015, 10:13 PM   #3
Registered User
Rewards Points: 526
Be sure to run your plan by the local AHJ. Plywood sub-floor has a perm rating of 0.70 (semi-impermeable) or so, usually no vapor barrier is required, check locally.
Gary
Building Crawl Space Access Covers red92s Building & Construction 8 11-02-2013 12:05 AM
Crawl space .. add a duct? beachfront71 HVAC 2 02-20-2013 06:53 PM
Converting Vented Crawl Space to Unvented/Conditioned Achille76 Building & Construction 4 02-19-2013 10:10 PM
Vapor barrier issue between crawl space and conditioned basement gregsenne Insulation 3 10-12-2012 12:53 AM
thoughts on crawl space heating rtoni HVAC 3 09-30-2008 01:47 PM
