Build A Stair On Rocky Grounds - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 10:50 AM   #1
Build a stair on rocky grounds
Hi,
I would like to build an outside stair that goes down around 15 feet, but the area is a solid rock, i have soil covering that ranges from 6 to 24 inches. Each time i try to install a 4 feet pile, i hit the rock. Is there any suggestions how to install the stairs on rocks ?
GKhammar is offline   Reply With Quote
Old 06-28-2011, 03:13 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 492
Is your stairs going to lay totally in the dirt or just the end of the stairs resting on dirt?
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 06-28-2011, 04:27 PM   #3
Rewards Points: 5,348
You plan the staircase and where it will hit the ground. You provide the landing by engineering a level pad. Maybe it's 4 sonotubes down to bedrock with an integrated pad formed on the ground. The sonotube lengths might vary, but stable is stable.
Ron
B. Franklin 1759
Old 06-28-2011, 04:54 PM   #4
AfterDinnerDIY.com
You could use a footer instead of a pile.
AfterDinner is offline   Reply With Quote
Stair rail help stubborn1 Carpentry 4 05-04-2011 08:39 AM
Stair Nose Attachment - HELP! BSponz1 Building & Construction 2 01-11-2011 08:51 AM
Stair Nose Attachment - HELP! BSponz1 Flooring 3 01-10-2011 02:31 PM
Need to build stairs--Is there a Stair Kit? Cocoxoxo Building & Construction 13 04-15-2010 09:52 PM
To Build or Not To Build scoby1978 General DIY Discussions 6 05-27-2007 05:39 PM
