DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Building & Construction (https://www.diychatroom.com/f19/)
-   -   Build a stair on rocky grounds (https://www.diychatroom.com/f19/build-stair-rocky-grounds-109045/)
GKhammar 06-28-2011 10:50 AM
Hi,
I would like to build an outside stair that goes down around 15 feet, but the area is a solid rock, i have soil covering that ranges from 6 to 24 inches. Each time i try to install a 4 feet pile, i hit the rock. Is there any suggestions how to install the stairs on rocks ?
BigJim 06-28-2011 03:13 PM
Is your stairs going to lay totally in the dirt or just the end of the stairs resting on dirt?
Ron6519 06-28-2011 04:27 PM
You plan the staircase and where it will hit the ground. You provide the landing by engineering a level pad. Maybe it's 4 sonotubes down to bedrock with an integrated pad formed on the ground. The sonotube lengths might vary, but stable is stable.
AfterDinner 06-28-2011 04:54 PM
You could use a footer instead of a pile.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
