Budget Sound Proofing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-03-2016, 03:55 PM   #1
Rewards Points: 20
I read on a blog a couple of steps that you can take to make an area a little more sound proofed. Essentially it was take some sort of material- sheetrock- and attach it will sound dampening adhesive. Along with the obvious things like using materials around the room to absorb sound, a door sweep, etc.
My concern is that would that make the walls come out further and leave a gap from the baseboard and original wall and therefore cause you to have to redo the baseboard?
Not sure why it matters but it is a bedroom. All rooms could use sound proofing but bedrooms are first priority. And yes I have googled sound proofing.
Last edited by jessicurr; 02-03-2016 at 04:16 PM. Reason: poster asked for more detail
jessicurr is offline   Reply With Quote
Old 02-03-2016, 04:11 PM   #2
Rewards Points: 17,808
Want to make an omelet going to have to crack some eggs.
Google "sound proofing".
Any right way is going to involve adding density.
May want to take the time to add more info.
We have no idea what room it is, where it is in the home.
Old 02-03-2016, 04:18 PM   #3
Rewards Points: 20
I'm sorry. That wasn't my question. My question was won't the wall stick out further with adding a layer of sheetrock?
Old 02-03-2016, 04:30 PM   #4
Think about that question for a min.
Really think adding a layer of sheetrock is even going to be noticed?
For any real sound proofing far more needs to be done.
Forget the "blogs" and do the suggested google search on "sound proofing a room" for real suggestions.
Old 02-03-2016, 05:20 PM   #5
kwikfishron's Avatar
Rewards Points: 162
Yes and it will effect all trim, door and window jambs, electrical switches and outlets too.
kwikfishron is offline   Reply With Quote
Old 02-04-2016, 12:15 AM   #6
Rewards Points: 1,036
its going to take more than sheetrock. your real prob is deciding how soundproof you want it and what method will fit your budget and level of construction you want to get into.
Mingledtrash is offline   Reply With Quote
Tags
drywall , remodel , sound proofing , soundproof
Sound proofing HVAC return duct JayBird HVAC 8 07-27-2012 12:25 AM
Insulation with Sound Isolation Clips atmironov Building & Construction 12 05-06-2010 03:44 PM
Heating/cooling/sound proofing a new home theater Neonblue HVAC 1 03-07-2010 12:19 PM
Sound dampening advice needed steel1 General DIY Discussions 10 10-22-2008 01:51 AM
Please Help me!!! Sound proofing problems karens General DIY Discussions 1 09-28-2008 02:05 PM
