Buckethead Shopvac Filter For Fine Particles - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-23-2017, 07:09 PM   #1
Rewards Points: 2,602
Buckethead shopvac filter for fine particles
I am going to be doing some cutting and grinding of stucco, concrete blocks, cement boards etc...and it will create a lot of dust.
I have one of those Buckethead shop vacs that you fit over a five gallon bucket and it uses a cheap paper filter. I don't think those filters would work against fine particles like cement and drywall dust and if it does it would clog in a minute.
Are there filters made for fine particles that I can use for that vac? Or are there any tricks anyone care to share? I know about keeping the saw or grinder wet to minimize dust in the air at the expense of creating "slurry" and splashes all over so that won't work in most of my cases.
Thanks in advance.
miamicuse is offline   Reply With Quote
Old 06-24-2017, 07:49 AM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
Re: Buckethead shopvac filter for fine particles
those bucket head vacs arent designed for dust extraction.. you need a heavy duty shop vac with a hepa filter or a actual dust extractor rated for concrete work
woodworkbykirk is offline   Reply With Quote
Please help ID what I found in my filter! daveccarsley Plumbing 24 10-11-2015 08:09 PM
Input and output hvac Duct too small LiL-Daddy HVAC 9 07-10-2014 06:40 PM
Would you choose a DIY box fan air filter over a manufactured air purifier? Druidia General DIY Discussions 1 03-14-2014 01:41 AM
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 01:05 AM
looking for filter for old shopvac ilyaz Tools 4 11-23-2010 09:22 PM
