Buck Frames For Windows? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-19-2008, 11:37 AM   #1
Post
Buck Frames for Windows?
Are buck frames needed in the rough openings for vinyl windows when tearing out the entire old window? The vinyl windows I am considering have no nailing flangs. The construction is newer sheet, wood, ply, and siding.
Jeff1417 is offline   Reply With Quote
Old 10-19-2008, 03:27 PM   #2
Rewards Points: 85
Jeff,
If you can get the manufacture's name from the windows already installed you could possibly get INSERTS that will replace the windows already in place.
Best of luck and happy hunting, rredogg
rredogg is offline   Reply With Quote
Tags
buck frame , rough opening
laminate floors and metal door frames homeimprovement Flooring 8 10-06-2008 12:47 PM
paint coming of from doors and frames np2008 Painting 6 03-06-2008 06:03 PM
Windows: brands? new frames? frogger Remodeling 8 01-16-2008 11:19 AM
Insulating metal window frames SagittarianLady General DIY Discussions 6 12-08-2007 09:36 AM
Condensation on Metal Window Frames: Should I Caulk? xquercus General DIY Discussions 6 06-29-2007 09:24 AM
