Brick Veneer Or Soffit/fascia First? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-12-2009, 12:14 PM   #1
Rewards Points: 1,910
Brick veneer or soffit/fascia first?
When doing brick veneer all the way up to aluminum soffit/fascia is it better to install the soffit/fascia before the brick or after the mason is done?
Old 11-12-2009, 09:27 PM   #2
Retired Moderator
Rewards Points: 7,174
Usually brick first then soffit, -MIKE-
Old 11-13-2009, 01:02 AM   #3
Tom Struble's Avatar
Rewards Points: 2,002
typically you should install a frieze board for a transition
brick right up to the soffit looks cheap
Tom Struble is offline   Reply With Quote
Brick veneer or Structural Brick? nimblemotors Building & Construction 19 02-22-2013 08:11 PM
another brick veneer problem question rdk4609 Building & Construction 6 06-12-2009 09:46 AM
New opening in a brick veneer wall - installing new brick ties? GrantJohnson Building & Construction 3 01-28-2009 10:17 AM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 08:21 PM
