Brick Column-how To Repair? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-16-2010, 12:30 AM   #1
Rewards Points: 978
brick column-how to repair?
[/IMG]So I noticed that the brick column of my porch has some damage to the brick. what can I do to repair it? or do i have to take that brick out on the bottom and install a new one? pic attached
[/IMG]
federer is offline   Reply With Quote
Old 10-16-2010, 01:50 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
it would appear that just about every brick in that column is in various degrees of failure. Depending on how far up the bad bricks go, It might be simpler to just take it down and rebuild if.
Old 10-16-2010, 10:35 AM   #3
Rewards Points: 978
thanks for the reply. the portion shown in the pic is definitely worse than the rest of teh column. so theres no way to just replace the bottom brick?
Old 10-16-2010, 02:03 PM   #4
Rewards Points: 582
You might get lucky with one of these in the bed joint.
stuart45 is offline   Reply With Quote
Old 10-16-2010, 02:14 PM   #5
Rewards Points: 978
what is that tool? is that for tuck pointing?
Old 10-16-2010, 02:42 PM   #6
Rewards Points: 582
It's a plugging chisel. It's used to cut out the mortar joints. If you can cut out the bed joint the brick will come out.
The Following User Says Thank You to stuart45 For This Useful Post:
federer (10-18-2010)
Old 10-18-2010, 11:59 PM   #7
Rewards Points: 978
so after i cut it out and get the brick out i can place a new one in there. but do i have to use a certain brick and mortar?
Old 10-19-2010, 01:13 PM   #8
Rewards Points: 582
If you are not replacing with the same type of brick I would go for a frost resistant type. It's probably the freeze/thaw that cracked the bottom ones. They usually suffer more because of rain bounce, or rising damp.
All bricks below DPC here now have to be frost resistant.
Old 10-19-2010, 10:29 PM   #9
Rewards Points: 978
thanks for coming back to this- whats DPC?
Old 10-20-2010, 12:09 AM   #10
Concrete & Masonry
Rewards Points: 464
Attachment 25801
That's something we call an "English Plugging Chisel" here Stu, imagine that.............
They atually work fairly well too, I used to carry one around in my bag until I lost it somehow............
jomama45 is offline   Reply With Quote
Old 10-20-2010, 07:37 AM   #11
Rewards Points: 582
DPC stands for damp proof course, which is put in 6 inches above ground level to prevent rising damp going up the wall.
Bricks below DPC are often damp and crack and spall in the winter, unless frost resistant ones are used.
Old 10-20-2010, 07:47 AM   #12
Rewards Points: 582
Joe, here's what we call an American plugging chisel.
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 04:07 PM
Brick work to repair a Chimney worthspending Building & Construction 2 10-17-2010 08:58 AM
Brick Walkway Repair onyx Building & Construction 1 10-15-2010 12:59 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Garage brick wall repair TANME General DIY Discussions 2 02-04-2010 07:19 AM
