Bowing House Wall - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-09-2010, 12:51 PM   #16
Rewards Points: 582
In the UK the end wall is called the gable and the triangle at the top is the gable end.
Your house looks like a typical cavity wall. Brick/2-3inch cavity/brick inner wall.
Was it built in the 60's?
stuart45 is offline   Reply With Quote
Old 04-09-2010, 01:07 PM   #17
I think we were told 40's or 50s when brought it. Do you know if it can be a DIY job? People are teling me different things, someone said re point and plaster inside it wont move anymore, been told will never sell house because of it, also told cant do it ourselves has to be a proffesional.
kcooper83 is offline   Reply With Quote
Old 04-09-2010, 01:17 PM   #18
Rewards Points: 582
Could be done DIY. Take up your floorboards and notch the top of the joists as shown in diagram. New houses have them built in now.
Tags
bowing wall , cracks in wall
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Sealing exterior wall from inside the house? BigJimmy Building & Construction 6 03-20-2007 09:16 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
