Is Blocking Considered Structural? Decks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-21-2017, 04:55 PM   #1
is blocking considered structural? Decks
Hi,
Is blocking on decks considered structural?
If my joists are 2x12 am I required by code to use the same dimension lumber for the blocking or can I go down to 2x4 , 2x6 ....
I found a stock pic of what I am considering, I am not a great artist..lol
but can the deck boards run the way i drew and can I use smaller lumber then the joists? As far as if code allows it....
m209 is offline   Reply With Quote
Old 04-21-2017, 04:59 PM   #2
Re: is blocking considered structural? Decks
I thought the pic was added but guess not...
https://postimg.org/image/ac945dzh1/
here is the link[IMG]https://postimg.org/image/ac945dzh1/[/IMG]
Old 04-21-2017, 06:00 PM   #3
concretemasonry's Avatar
Rewards Points: 2,716
Check with your local building office.
It could be a local or seismic requirement, which can over-rule a national model code that may have been adopted by a state or city.
Are you in a seismic area?
Dick
concretemasonry is offline   Reply With Quote
Old 04-21-2017, 06:57 PM   #4
Originally Posted by m209 View Post
Hi,
Dick
Thanks. No im not in a seismic area. I live in PA.
My building code doesn't over ride any national model code. On all the building plans it states that they have adopted the IRC as code.
I just cant find it in the IRC about my specific question.
Do you know if the IRC allows what I am proposing?
Old 04-21-2017, 07:01 PM   #5
Rewards Points: 1,680
Don't know the answer.....but part of what blocking does is to keep the joists from twisting.....and a two bye four isn't going to do a lot for a two bye twelve. Ron
ront02769 is online now   Reply With Quote
Old 04-21-2017, 07:47 PM   #6
Good point didnt think of that
Old 04-21-2017, 07:48 PM   #7
jlhaslip's Avatar
Rewards Points: 708
If the blocking is carrying the decking material, ie: the decking is running the same direction as the joists, then yes, in this instance it is structural in that it is carrying the load placed on the decking.
I would consider using hangers for those blocks. Nails would not be strong enough to trust in this case, IMHO
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 04-22-2017, 06:16 AM   #8
Rewards Points: 898
You only have a 14-1/2" span. I'd up the blocking to 2x6, offset 1-1/2" from each other and use 3 galvanized ring shank gun nails on each end.
BIG Johnson is offline   Reply With Quote
Brick veneer or Structural Brick? nimblemotors Building & Construction 19 02-22-2013 09:11 PM
Retrofit attic baffles with blocking in open eaves jkk Insulation 9 07-27-2012 07:01 PM
Open cornice rafter bay blocking. diyroofer Building & Construction 7 09-05-2011 01:55 AM
Is blocking required for ceilings? ChrisJJ Drywall & Plaster 3 08-22-2010 11:47 AM
Concrete steps and stucco cracked-Is this structural problem? yummy mummy Building & Construction 17 04-14-2008 10:24 AM
