Blocking Around Mounting Bolts? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-11-2010, 01:59 PM   #1
the Musigician
DangerMouse's Avatar
Blocking around mounting bolts?
Can I block around the bolts as shown and then hang my 2x12 floor joist to keep an even 16" spacing? AND pass the inspection? or do I have to offset them when I run across the bolts?
that'd stink...
DM
Old 02-11-2010, 02:17 PM   #2
Rewards Points: 5,348
If recessing the bolt isn't readily feasible, why not just notch out the joist so the nut fits into it? The joist will be set into a hanger so there shouldn't be an issue with the notch.
Ron
Old 02-11-2010, 02:26 PM   #3
the Musigician
the bolts are through the 6x6s and 2 12" LVL rim joists, and need to be surface mounted. can't sink 'em.
although i think your idea of notching it would be easier and should be approved.
I'll run it by my architect and the inspector....if I can find him.....
thanks!
DM
Leaking tank bolts splinters Plumbing 4 12-25-2009 06:04 PM
Leaking tank-to-bowl bolts on toilet MI-Roger Plumbing 8 10-18-2009 08:29 AM
galvanized bolts for pressure treated wood? Jeremy Hillary Boob, PhD Building & Construction 11 07-10-2009 09:53 AM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 04:26 PM
Fishing a wire around blocking? rjniles Electrical 10 12-16-2008 10:14 PM
