Big Crawl Space - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-14-2012, 03:59 PM   #1
Big Crawl Space
Hey guys! I am barely just a new homeowner and would like to know if i can do anything with my crawl space. It looks like this....Big Crawl Space-crawl-space.jpg
losx0908 is offline   Reply With Quote
Old 06-14-2012, 05:41 PM   #2
Retired Moderator
Rewards Points: 7,174
Give us a clue ---what would you like to do with it?
Old 06-14-2012, 05:42 PM   #3
Rewards Points: 1,336
I take it this is built on the side of a slope. Does the wall on the right side(picture) go as deep as the wall on the left?
danpik is offline   Reply With Quote
Old 06-14-2012, 06:00 PM   #4
well since i'm a big music guy i would love to make my own home studio here! The wall on the right hand side does not go deep enought like the one on the left. My plans for next week are to excavate the dirt and level it! I just dont know if i will need some addittional house support.
Old 06-14-2012, 06:00 PM   #5
and yes the house is built on a slope. A BIG SLOPE I WOULD SAY!
Old 06-14-2012, 06:06 PM   #6
Old 06-14-2012, 09:28 PM   #7
AHH, SPANS!!!
Rewards Points: 1,166
excavating around the support piers might be your challenge. maybe they poured deep footings but then again...
hand drive is offline   Reply With Quote
Old 06-14-2012, 10:02 PM   #8
I just gotta see how much will be the cost to insulate the side walls and to pour cement.
Old 06-15-2012, 04:35 AM   #9
There has to be something else in your home you could better spend all that time, money and effort on...
scottyohno is offline   Reply With Quote
Old 06-15-2012, 07:25 AM   #10
Rewards Points: 614
A good slope like that deserves a home theater!
puttster
puttster is offline   Reply With Quote
Old 06-15-2012, 08:20 AM   #11
Yes a theater sounds like a good idea too! The only thing i want to do is convert this into 'living space' but i don't really know where to start. All i'm doing is just excavating and leveling the dirt. After that i have no clue...
Old 06-16-2012, 01:04 AM   #12
Registered User
Rewards Points: 526
If you decide not to, at least fix the right-hand flex duct that is crimped at the bend by the strapping:http://rockwallcontrols.com/Resident...ag=air-ducting
I doubt you are getting much air pressure through that one: http://www.thefreelibrary.com/Pressu.....-a0201591046
Cover the joist bottoms with house wrap to deter air movement in your fiberglass insulation, or foam board: http://www.buildingscience.com/docum...n-crawlspaces/
Insulate the rims; http://www.buildingscience.com/docum...l_seal_rev.pdf
Gary
Old 06-16-2012, 09:16 AM   #13
whoa.... i didnt know all that work had to be done....i'll get right to it! thanks for the info!
Crawl Space cleitch Building & Construction 4 05-28-2012 10:57 PM
Cement crawl space ventilation sheslostcontrol HVAC 9 05-22-2010 09:32 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 01:09 PM
32 inch high crawl space can a furnace fit tommar HVAC 4 02-20-2008 06:28 AM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 09:15 PM
