Bevel Cuts Necessary Here? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 09-12-2017, 12:18 PM   #1
Rewards Points: 207
Bevel cuts necessary here?
Building a California frame tie in for gable. Is it required to cut these long bevels as shown in the first picture? Versus the other way shown in second picture.
wease is offline   Reply With Quote
Old 09-12-2017, 12:24 PM   #2
retired framer
Rewards Points: 6,106
Re: Bevel cuts necessary here?
The second one is fine let the sheeting run right over to touch the other sheeting.
Our truss companies supply truss sets for that and then you don't have the soul plate, just sheet on sheet.
The Following User Says Thank You to Nealtw For This Useful Post:
wease (09-12-2017)
Old 09-12-2017, 12:44 PM   #3
Rewards Points: 207
Thanks Neal. I wonder why some guys do that difficult bevel cutting.
Old 09-12-2017, 12:55 PM   #4
retired framer
Protectionists working by the hour. and not framers on a tight quoted job.
wease (09-12-2017)
Old 09-12-2017, 01:26 PM   #5
Rewards Points: 207
One more thing, I noticed 2x material for that area too. Why not 1x? Get it closer to the sheathing.
Old 09-12-2017, 01:31 PM   #6
retired framer
The ends of the rafters can land away from support from below so it has to be enough to spread that load. A 1 x may not be stiff enough. And how many different specs. do you want to deal with while on the roof.
NotyeruncleBob likes this.
wease (09-12-2017)
Nordyne FGTC080-VC cuts out jncpilgrim HVAC 3 11-21-2016 04:14 AM
Need 6-1/2 saw blade for smooth cuts (Melamine) with 18v cordless circ saw homeimproverjoe Carpentry 29 08-03-2016 05:36 PM
Hitatchi C 10fce2 bevel problem! George in GA Tools 6 12-14-2015 02:42 PM
Double Bevel Miter Saw jburchill Tools 4 10-27-2011 11:48 PM
How to properly fill stress cuts in concrete before tiling? vseven Tiling, ceramics, marble 20 06-07-2011 09:53 PM
