Best Way To Insulate Under A Bay Window? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-12-2009, 08:08 PM   #1
Rewards Points: 267
best way to insulate under a bay window?
i guess i was very naive about how much cold can penetrate up through the bottom of a bay window. i very lazily attempted to stuff some batting in the void between the bottom of the window and the vinyl siding.. looking back now it was completely useless..
so now the cold really comes up through the wood bottom/base of the window.. If i decide to open up the siding outside and get to the bottom of the window what is the best way for me to insulate? Batting doesnt work because you cant get it to "stick" under the window. i guess i could use XPS but it would take me hours to make all the cuts (oval window) to get it to be air tight.. honeslty what i really need is about 6 feet of spray foam. Any suggestions?
windowguy is offline   Reply With Quote
Old 12-12-2009, 08:34 PM   #2
Rewards Points: 267
i just searched the forum and someone asked the exact same question 10 months ago.. i guess the answer is XPS
Old 12-13-2009, 06:08 AM   #3
There are DIY spray foam kits available, but I prefer to leave that to people that understand foam installation and types. For bays/bows I install I use XPS. Depending on how much space i have, I will usually use at least 2 layers of 2". Liguid nails holds it in place until I can cover it with vinyl or aluminum.
Bathroom window issues? Mantaray14 Remodeling 11 12-04-2009 07:40 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
