Best Saw Blade For Treated Wood???? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-17-2009, 11:40 PM   #1
Rewards Points: 562
Best saw blade for treated wood????
Just wondering if some blades work better than others for cutting new treated lumber.??
the cheapie blade in the borrowed saw I used today jammed plumb tight and wouldnt let go today.
Do "SOME" blades have more kerf than others to give blade more relief??
4just1don is offline   Reply With Quote
Old 08-18-2009, 08:04 AM   #2
Registered User
Termite's Avatar
I presume we're talking about 7-1/4" circular saw blades...
There are the standard kerf thickness framing blades that most of us use. Assuming they have carbide teeth they're the right thing to use. A framing blade has something like 24 teeth because the wetter lumber's dust is hard to clear from the cut, and blades with more teeth don't cut as aggressively. That's what I'd use. All the major brands are fine.
I do have some thin kerf blades for my circular saw. One is a 60 tooth thin kerf carbide blade I use for cutting large sheets of hardwood plywood into more manageable sizes for the table saw. I wouldn't use it on treated lumber though...Too many teeth to clear the wet dust.
If your blade bound in the wood it is probably because the kerf is trying to close on it...Wet wood (southern yellow pine especially) tends to freak out and move, especially when ripped lengthwise. I presume that you weren't cutting a board between support points like sawhorses, which is dangerous and would certainly bind a blade.
Cheap-o saws sometimes also lack the guts to make some cuts. A good hypoid or worm drive saw is much more difficult to slow down compared to a $39 black and decker.
Old 08-18-2009, 04:24 PM   #3
Rewards Points: 562
Thanks KC, I found a good old sharp blade in my basement and I put that on and it works fine now. I looked for the one with the widest teeth and cut.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
