Thread Tools | Display Modes |
#1 |
Young Bachelor
Rewards Points: 479
![]() Best Practice : Attach deck ledger board to rim-board w/ I Joists
Looking for someone who has done this in the past - with success...
How does one go about attaching a ledger board, say a P.T. 2x10, to a rim board when the rim-board is fastened to I joist flanges? Right now I have vinyl siding > housewrap > rim board > I joists. I have a bad feeling about tearing off my bottom row of vinyl siding, and just using lag bolts to secure a P.T. 2x10 to the rim board. Wouldn't the rim-board be apt to pull out / pivot on the sill plate since it's only secured to the joists at their flange points? I know if this was the older style 2x joists, I would just lag my P.T. 2x10 directly through rim board and into the meat of the house floor joists. That's not really an option with modern construction, so what is the best practice? |
Sponsored Links | |||
Advertisement |
#2 |
JUSTA MEMBER
Rewards Points: 364
![]() Re: Best Practice : Attach deck ledger board to rim-board w/ I Joists
A picture would be great help.
ED |
Advertisement |
#3 | |
Rewards Points: 1,036
![]() Re: Best Practice : Attach deck ledger board to rim-board w/ I JoistsQuote:
Also nowadays they require some serious anchors on your porch if its not free standing. ![]() Last edited by Mingledtrash; 07-25-2016 at 08:01 PM. |
Advertisement |
#4 |
Young Bachelor
Rewards Points: 479
This isn't mine, but this is exactly the same thing going on, perhaps mine is with a tighter joist spacing.
I'm wanting to attach to that rim board the joists are perpendicular to. As you see, the flange is the only meat the rim-board has attached to the joists. @Mingledtrash , I am unsure of how well the sub-floor was nailed into the rim-board. If I was there I would have definitely glued and nailed that edge very well knowing later I would have a ledger board, but I was at work that day during construction. One thing I do remember now though, is that the wall OSB (7/16) spreads down over the rim board, so technically that should be extra support to prevent the rim-board from tearing back / pivoting, yes? This deck would run 10 to 12' out from the house and be 16-20' along the house, making the ledger be that 16-20' length. I am tempted to just build this free standing, but that's going to put some supports in difficult places at the walkout basement door area. |
#5 |
JUSTA MEMBER
Rewards Points: 364
Thank you for the picture.
Do you have access to the inside crawl space, or basement? If so go in there, add some 2X ? as backing joists, like fire blocks, but rim joists. Then through bolt the exterior ledger board into these support joists . ED |
#6 |
Young Bachelor
Rewards Points: 479
I can get to that area in the basement just fine. I have thought of how I could brace that area, but even the idea of some 2x? The 2x would need to secure to the I joists somehow, yes? But how would this happen since it's an I joist and the center OSB material is off limits in terms of support? Just running 2x material behind the rim board wouldn't do anything unless the 2x material anchors to the joists, but then it's really choppy there - at least in my mind.
#7 |
JUSTA MEMBER
Rewards Points: 364
You place your 2X against the OSB , then toe-screw up and down into the caps.
Use 2.5- 3 inch coated deck screws. This strengthens the I-beam immensely. Then you can bolt through from the outside, the ledgers for the deck. ED |
#8 |
Young Bachelor
Rewards Points: 479
Caps...as in the flanges of the I Joists? Then the goal is to fasten the ledger into the dimensional 2x material on the inside?
#9 |
JUSTA MEMBER
Rewards Points: 364
Caps are either the I joist flanges, or the top or bottom plates of the upper and lower structure.
Yes on the inside, bolt through the OSB t get into the 2X that you just installed. ED Last edited by de-nagorg; 07-26-2016 at 01:01 PM. Reason: add to |
#10 |
Young Bachelor
Rewards Points: 479
So you are saying to sister the 2X with the rim board, running it perpendicular to the I Joists? Just checking to clarify...
#11 | |
JUSTA MEMBER
Rewards Points: 364
That will be strengthening the OSB rim, and giving the floor joists a bit of help too. And it gives you plenty of material to bolt the deck ledger to. Especially if you do this in every span. ED |
#12 |
Rewards Points: 1,466
Typically your rim joist is nailed every 6-8 inches at the bottom into the sill. Then a couple of nails into the top of each I joist. Then the whole thing is covered with plywood nailed 12" in the field, 6" on all seams.
If your rim board is the modern stuff which is typically apa rated and either 1" or 1 1/8" thick you should have no worries provided that you use proper fasteners to attach the ledger. Ron |
Advertisement |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Installing deck ledger board over foam board? | RickT | Building & Construction | 9 | 04-27-2018 12:41 PM |
2nd story deck ledger | ERMaag | Building & Construction | 8 | 02-20-2015 03:13 AM |
Deck Ledger Attachment | Mick Gregory | Building & Construction | 7 | 02-23-2012 09:37 PM |
How do I attach a ledger (for a 2nd story deck) if there is no rim joist? | jrdamien | Building & Construction | 11 | 08-05-2009 07:25 PM |
replacing rotted sill plate and rim joist behind a deck ledger board | tommyt | Building & Construction | 2 | 08-11-2008 08:38 PM |
