Best Caulk For Plastic - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-02-2010, 06:26 PM   #1
Best caulk for plastic
Can someone tell me if regular 100% silicone will burn through 6 mil plastic ? Im wanting to create a seal between two pieces of plastic and Ive heard that silicone can melt away that rigid foam board material but wasnt sure about the black 6 mil plastic.
Mudball is offline   Reply With Quote
Old 01-02-2010, 06:38 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 32,344
Silicone will not melt or stick to plastic. You need to use acoustical sealant to stick plastic.
Old 01-02-2010, 10:34 PM   #3
Thanks joed. I really would like to apply something between two pieces of plastic in addition to some sealing tape. I currently have some caulk that is specifically designed for adhering foam board to other surfaces. It sounds like acoustical sealant will do the trick for the plastic.
I forgot to mention that my goal is to try and eliminate the flow of moisture and/or air between the two plastics.
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 37 06-05-2017 05:19 PM
Can anyone recommend a good caulk? lhhandyman Plumbing 7 06-01-2009 05:22 AM
caulk question scatterbrain General DIY Discussions 5 10-04-2008 06:57 PM
Caulk Frustration j4ino Building & Construction 5 09-29-2008 07:03 AM
recaulking: cleaning out old caulk questions adamc Painting 6 09-19-2008 05:30 PM
