Below Freezing Temps - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-28-2010, 07:06 PM   #1
Below Freezing temps
My duplex that I live in is built on a concrete slab. I was told that when the temperatures get below freezing my water pipes should be fine withOUT having to leave a faucet dripping or running. Is this true?
LindaMac60 is offline   Reply With Quote
Old 12-28-2010, 07:19 PM   #2
A Little Of Everything
Rewards Points: 1,436
That should be true in ANY home.
Can you give us any more information - such as where you live, a bit more about the duplex, etc.?
Oh yeah - and welcome to the forum!
DrHicks is offline   Reply With Quote
Old 12-28-2010, 08:02 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 32,008
Are the water pipes under the slab? If they are, you should be fine. The heat from the house heats the slab. Water pipes outside the house or in the attic could be a problem.
Old 12-28-2010, 08:18 PM   #4
concretemasonry's Avatar
Rewards Points: 2,716
The outside conditions and depth of the lines will control since lines below a slab in a heated home should not be a problem.
I lived in a home in northern MI with a basement, but the lines were not low enough in comparison to the theoretic "frost depth" due to the level of the natural rock that determined the utility depth.
The city REQUIRED owners to leave a trickle of water running at the lowest faucet for a couple of months and reduced the utility costs for that period.
It all depends on the local situation.
Dick
concretemasonry is offline   Reply With Quote
New A/C unit won't cool in hot temps wishiknewmore HVAC 39 06-28-2012 08:51 PM
is it bad to do masonry work in (near) freezing temps? amakarevic Building & Construction 6 12-22-2010 06:52 AM
Outdoor faucets and freezing temps DaveinGA Plumbing 17 01-07-2010 07:48 PM
Freezing Temps + Broken Hose = Water everywhere Leah Frances Off Topic 8 12-14-2009 08:55 AM
New house, freezing temps, loud popping noises lp61006 Building & Construction 11 02-22-2008 05:36 PM
