Bedroom Door With Step Down - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-09-2009, 10:29 PM   #1
Bedroom door with step down
I have a bedroom, off the entry way of a cabin, that is about 8" lower than the rest of the house. So when you enter the bedroom, you have to step down (one step). I am going to put a door on this and am wondering which way the door should swing, into the room or out of the room. I know that bedroom doors should swing in, and doors at the top of stairs should swing out. Since this is both, which one wins out?
Fleener is offline   Reply With Quote
Old 06-10-2009, 05:18 AM   #2
Remodeling Contractor
swing it in and add a landing inside the bedroom. Then step down from the landing.
Old 06-10-2009, 06:24 AM   #3
And put up warning signs for guests/visitors.
Old 06-10-2009, 06:47 AM   #4
Yeah the landing on the inside seems right
If the door opens in they won't be able to see as they open the door. And a landing is required by code
I might be inclined to use (2) 1/2 doors that each open instead of 1 big door if space is an issue
Old 06-10-2009, 07:01 AM   #5
the Musigician
DangerMouse's Avatar
orrrrrr..... put in a pocket door and don't worry about the swing....
DM
tiling outdoor step kristinmcdonald Tiling, ceramics, marble 6 06-08-2009 11:02 PM
Step footing has gaps joshoc Building & Construction 4 05-06-2009 04:11 PM
Beautiful Bedroom Renovation! EdinDesign Project Showcase 11 10-03-2008 01:40 PM
How Should I Frame this Single 10' Wide Step? Chris' Place Remodeling 4 04-02-2008 09:31 PM
your guestimation and or opinion on removing a bedroom shan Remodeling 2 12-09-2005 03:46 PM
