Beam Removal - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By ktmrider
Old 10-21-2017, 11:11 AM   #1
Rewards Points: 6
Beam removal
Newbie with pictures ( I hope they post ???) , Attic pic is above room with the 2 beams in question.
Hope this is the proper area to post this question...
Nutshell, 2 beams in room with high ceiling, wife wants them gone if possible, she was once told by neighbor with same house/room that they removed theirs.
I don't wanna be "that guy" who makes an expensive mistake , are these ok for me to take down ?
Thanks all !!!
River1 is offline   Reply With Quote
Old 10-21-2017, 11:18 AM   #2
Rewards Points: 6
Re: Beam removal
That's the attic pic I mentioned in first post...
Old 10-21-2017, 12:17 PM   #3
jlhaslip's Avatar
Rewards Points: 708
Re: Beam removal
By removing them you risk having that exterior wall develop a bow to the outside.
Those beams look like they serve a purpose. They keep the wall plumb and straight.
Best to pay for an onsite inspection by a competent Framer or an Engineer.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-21-2017, 12:27 PM   #4
Rewards Points: 9,416
Re: Beam removal
Exactly, only a structural engineer can give you a definitive answer, not anybody on a DIY forum.
However, my two cents is that its pretty clear you can not remove those beams. Look in the first picture how the roof is angled and trying to push the wall "outward". The beams are keeping the wall from moving outward. They are not there because somebody thought they looked good.
SPS-1 is online now   Reply With Quote
Old 10-21-2017, 03:46 PM   #5
Rewards Points: 542
Re: Beam removal
Search "collar ties". For me, those beams are spaced too far apart, unless the outer wall has its own reinforcement.
But measure first. Collar ties are up to 1/3 way up from where the rafters (roof joists) sit on the outer wall. Rafter ties are up to 1/3 way down from peak, but rafter ties don't do anything to keep the outer wall from pushing out.
carpdad is offline   Reply With Quote
Old 10-21-2017, 07:11 PM   #6
Rewards Points: 2
climb up there and see what they are made of,if they are structure they will be 2xs if they are false beams they will be hollow with 1xs
Msradell likes this.
ktmrider is offline   Reply With Quote
Old 10-22-2017, 11:46 AM   #7
Rewards Points: 6
Re: Beam removal
Thanks everyone for your quick responses. Will let you know how it turns out !
Old 10-22-2017, 01:59 PM   #8
Rewards Points: 1,066
Re: Beam removal
Can't tell from here, but there is a chance that they're just cosmetic and not serving any structural purpose. But you can't take 'em out till you know for sure!
NotyeruncleBob is offline   Reply With Quote
Column location for LVL Beam Perry401 Building & Construction 1 09-11-2013 12:27 AM
Help with building a beam for the basement Bonebag Building & Construction 13 04-02-2013 11:01 PM
Drilling vertically through structural beam? dyi_sometimes Building & Construction 15 11-01-2012 01:43 PM
Old powder post beetle damage to beam in basement - is it really a problem? nezwick Building & Construction 5 10-09-2012 10:12 PM
Ductwork Around Center Beam Build HVAC 6 06-16-2009 11:56 AM
