Beam Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-22-2020, 10:06 AM   #1
Rewards Points: 36
Beam construction
Building a 24x20 structure and I want a 20’ beam splitting it in have to rest the second floor joists.
I can get some expensive I beams or make my own. How do you construct a beam worthy of supporting the second floor... The beam would be testing on 24” of studs on each end
Cambraupod is offline   Reply With Quote
Old 05-22-2020, 04:38 PM   #2
Rewards Points: 4,326
Re: Beam construction
I would not construct it, I would buy micro lams in the size and number necessary. Most decent lumber yards will take the info and contact the manufacturer to have their engineer size them. Then brace it so it can’t rotate. The top of a beam is in compression and the bottom is in tension, so they try to equalize by rotating. Most beam failures are not from the beam breaking in half, rather, the beam rotates and fails.
Old Thomas is online now   Reply With Quote
Old 05-22-2020, 06:34 PM   #3
retired framer
Rewards Points: 15,680
I would not expect it to be no less than a 6x14" beam and nothing you can build out of pieces of lumber.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 05-22-2020, 11:09 PM   #4
Yea, Nealtw. I did a 24 foot span and it used 3 microlams 14” deep and 1 3/4” thick.
