DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Building & Construction (https://www.diychatroom.com/f19/)
-   -   Beadboard on balcony (https://www.diychatroom.com/f19/beadboard-balcony-53067/)
Cecosugi 09-15-2009 06:44 PM
1 Attachment(s)
We are building and I need to decide what to put on the walls of two very small balconies. I (think) I have attached a picture to show you what kind of exposure to the elements the balconies will have. They are about 6 x 6, with a roof, and are on the second story, but above a walkout so are really 3rd story off the ground. I don't know if that makes a difference when you are figuring wind blowing rain. They are open only on one side, which faces East. I would like to put beadboard up on the walls and ceiling, then seal it. The house is stick-built, but with timber accents and faux stone in certain places. So I need a style of wall and ceiling that will go with the style of home.
My question is...what wood-type of beadboard would you use? Beadboard comes in pine, I know, and cedar (and I'm sure lots of other types of wood, but I think these are my options). I am concerned about putting pine outside, even if it is in a rather protected environment. We've used cedar for the window trim, etc. Inside, we've used pine t&g and pine log siding. Obviously the pine is going to be less expensive. I'm just unsure of how it will weather (i.e. warp, fail in some way, have to be replaced quickly). We have painted the exterior walls and floor with elastomeric, so I'm not concerned about leaking through...mostly just concerned about the weathering. The floor will have a rubber barrier that goes 8" up the wall, under whatever we put on the walls, so that is not a concern, either.
Forgot to mention... the floor is sloped out, of course, and I live in Missouri.
Cecosugi 09-16-2009 10:44 AM
Is there a better place to post this question?
bsperr 09-16-2009 02:56 PM
I would imagine that the cedar would weather better, but you could also look at some non-wood options. James Hardie makes their fiber cement 4*8 sheets in beadboard pattern, which would be a lot more durable.
Cecosugi 09-16-2009 03:00 PM
Well that's an idea. I wonder if they make it in their Mahogany wood-looking color. That's what our house is. Then again, maybe I don't want to match the outside.
In any case, that's a great idea. I will look into it. Thanks.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
