Bathroom Loading - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-24-2010, 06:55 PM   #1
Bathroom loading
I doing a bathroom reno and would like to install a deeper tub. The tub i want to install required 45lbs/sq ft of Live load. I know that most houses are designed with an avg. of 40/sq ft and that because my tub is right beside the load bearing wall I shoulf be ok. However when I was doing some renos on the main floor I noticed that for some reason (I think because of no load bearing at the stairs) The is a 28"-30" space with no joist.I have done the calcs for a standard 2x8 SPF for 40lbs/sq ft and the max span is 12'-8" and for 50sq ft is 11'-5", but I don't know about the lager space. Does that beam make up for the space? I have attached a sketch to explain.
I have an engineer friend that can help me out but I would like some advise before I go see him.
damb is offline   Reply With Quote
Old 01-25-2010, 06:11 AM   #2
bump.
Basement bathroom rough in efrobert Plumbing 2 06-23-2011 04:54 PM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 12:17 AM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 10:10 AM
