Bathroom Exhaust Fan - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-24-2010, 09:58 PM   #1
Rewards Points: 150
bathroom exhaust fan
Has anyone ever heard or seen an exhaust fan installed right inside the shower, rather in the center of the bathroom?
If so, what you install one? (Is there any reason why this would be a bad idea)
-gramps
gramps416 is offline   Reply With Quote
Old 06-25-2010, 05:57 AM   #2
It is done all the time. Requires a fan rated for damp locations, it will be marked as such on the box.
It is usually better to locate a fan outside the shower area, but it can be close. There are other things the fan needs to evacuate, or just to move moist air.
Old 06-25-2010, 07:28 AM   #3
Knows everything but that
Rewards Points: 150
The fan I installed I put directly over the shower. It states on the box and in the insructions that it needs to be on a GFCI protected circuit so I used a GFCI breaker.
JakAHearts is offline   Reply With Quote
Old 06-25-2010, 09:35 AM   #4
Rewards Points: 150
are you refering to cheap fans that cost $50. I was looking at panasonic fans in the $200 range. Our local home hardware has them, and amazon gives them good reviews.
I hope this is what you are refering to, the fans that just move air around rather than the panasonic models.
Old 06-25-2010, 10:51 AM   #5
Rewards Points: 5,348
Water vapors from a shower will run all over the ceiling. Putting a fan in the shower area will not catch all the steam that is produced, it will drift through out the bath. Whenever I install these in baths, they are centrally located to work more efficiently.
Ron
adding can lighting and bathroom exhaust fan to aluminum wired house matjam68 Electrical 2 03-22-2010 10:50 AM
Basement bathroom exhaust fan install krusty HVAC 5 09-15-2009 07:41 PM
Bathroom exhaust fan Barry J Remodeling 11 09-06-2009 09:28 AM
Bathroom exhaust fans PirateKatz HVAC 7 11-18-2008 03:09 PM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 07:59 AM
