Basement Walls Squeek - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-28-2016, 03:21 PM   #1
I'm in the process of framing my basement using floating framing (code requirement). The interior walls that I have installed squeak and creek when walking on them from the floor above my basement. The walls feel solid and it's happening to walls that are connected directly to the joists and to the walls that are connected to blocking between joists. They only squeak and creek when walking above them. If I push and pull on the walls themselves they don't make any noise and feel solid. Will the noise subside after they're drwalled? What can I do to stop the creaking? Obviously I would prefer to take care of this before I drywall.
RookieDIYer8476 is offline   Reply With Quote
Old 08-28-2016, 07:06 PM   #2
Rewards Points: 1,380
Re: Basement Walls Squeek
are your holes in the bottom plate big enough? Basically what you are doing is hanging a wall from your joists.....a bit above the pt bottom plate. Your wall then "rides" up and down on steel rods that go through into the concrete. Not sure where you're from......but since I am on the ocean I see docks every day that are held in place by pilings driven into the ocean floor.....with a big u shaped thing that goes around the piling and connects to the dock....ands they slide up and down year after year....but they DO creak and squeak. So is that possibly your issue??
ront02769 is offline   Reply With Quote
Old 08-28-2016, 07:14 PM   #3
Rewards Points: 17,954
Got some pictures to share?
How where the brackets installed? Nails. screws?
Old 08-28-2016, 08:02 PM   #4
It does sound like it's coming from the spikes going through the bottom plate and into the pt sole plate. I'll try overdrilling the holes a little bigger to see if that does trick.
Painting tricky Basement walls. What paint should I use? tw1208 Painting 1 10-12-2012 08:07 PM
Insulate unfinished basement walls? DennyF Insulation 3 02-28-2012 12:36 PM
What to do with basement walls. RR. Remodeling 3 02-20-2012 06:49 PM
framing basement walls with furred ceiling BlueBSH Building & Construction 10 08-05-2011 12:44 PM
Basement Walls Plaster what to do? The Vintage Sou Building & Construction 5 11-19-2009 03:42 PM
