Basement Wall Finishing Help??? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-02-2010, 02:33 PM   #1
Basement wall finishing help???
I am in the process of finishing my basement and when the builders built the house, they already dry-walled part of the stairway going down to the basement. However, there is a section to where they stopped where the foundation begins. My question is, is there a way to just glue a piece of drywall onto the foundation because there is no rooms to build any type of wall or anything because the steps are there. I was thinking I could moisture proof the concrete and then attach drywall with some sort of adhesive. Any ideas or advice. I attached the pic below.
gabel8 is offline   Reply With Quote
Old 11-02-2010, 04:01 PM   #2
SteelToes's Avatar
Rewards Points: 150
Basement wall
Hey gabel8,
My name is George and I work for a Chicago area Home depot. In my opinion you can attach the first sheet of drywall (using some drywall adhesive) up to your first riser same like they have before, it looks like they went straight over the concrete with drywall. For the remaining part of the basement I would consider using furring strips and check with your code enforcement officer, you may need to insulate your walls.
SteelToes is offline   Reply With Quote
Old 11-02-2010, 04:16 PM   #3
Thanks George, The area is only about 4 feet long and they don't drywall over the foundation, that is actually where the foundation ends.
Old 11-02-2010, 09:12 PM   #4
Registered User
Rewards Points: 526
Where are you located?
Gary
Old 11-03-2010, 05:38 AM   #5
Pittsburgh, PA
Old 11-03-2010, 03:48 PM   #6
Registered User
Rewards Points: 526
If your zip starts with 152, recommended basement exterior insulation = R-12, interior = R-11. You should get a permit for the paper trail for H.O. Insurance and when you sell the house. Ask if the stairs are required to meet egress for width, if not and only a basement widow/door is required, you can frame over the stairs for the insulation thickness. This on general basement insulation: http://www.buildingscience.com/docum...ent-insulation
This for more understanding the summertime problems of vapor control: http://www.buildingscience.com/docum...gs?full_view=1
Read them and ask away……
Gary
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Interior Basement Wall finishing tookie Building & Construction 0 01-01-2010 04:04 PM
Basement Wall Mortar rory535 Building & Construction 16 08-06-2009 09:39 AM
subpanel mounting on concrete basement foundation wall bulk88 Electrical 12 03-10-2009 01:38 PM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 12:24 PM
