Basement Wall Covering - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 11:40 PM   #1
Rewards Points: 135
Basement wall covering
I am looking to put up some wall covering to finish off my laundry room in the basement. the issue I have is right by the stairs, I don't have enough space to put a lot of backing support. Would it be possibly to put up a 4x8 sheet of the beadboard looking panel and just securing it at the top to the sill and the bottom to the stair stringer and using 1 x 1/4" strips glued to it to space it off the wall so there is an airspace. The walls have been sealed before and I don't get water from any of the walls in the laundry room currently. This would only be for a 12 foot section near the stairs and the walls are concrete.
Thanks.
jimmyfloyd is offline   Reply With Quote
Old 12-13-2010, 02:57 PM   #2
Rewards Points: 135
Some things do get through the spam filter I see...
Old 01-04-2011, 04:51 PM   #3
Rewards Points: 135
Here is a picture of the area I want to put the wall up in. As you can see, there isn't a lot of space here.
Another thought I had while reading some other basement posts was 1/2" - 1" XPS foam and then just attach the bead board to that directly with no drywall or studs. Would that be an option? Or do I need a small airspace between the foam and the bead board?
Old 01-04-2011, 08:52 PM   #4
Rewards Points: 162
That is a pretty narrow space to work in. If it were me and I had to have a finished look, I would install 1" furring strips against the wall and then fasten the paneling to the wall. You'll need to install a handrail, so the furring strips would give you a little material to attach to as well.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Covering a Basement Wall That is painted jordan83 Building & Construction 2 11-02-2010 10:13 PM
Insulating Exhisting Basement Wall soasquad Building & Construction 3 01-10-2010 07:56 AM
Basement wall prob Spalding101 General DIY Discussions 4 09-25-2009 11:55 PM
Basement leaks in brick wall Nick General DIY Discussions 8 07-18-2006 05:29 PM
Basement wall Problem dazusa Building & Construction 2 01-20-2005 10:16 AM
