Basement Vapour Barrier - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-29-2010, 03:47 PM   #16
Rewards Points: 192
Most of the above posts seem to be in conflict with the approach recommended by buildingscience.com and other current sources. A foam approach is ideal in a basement but in any case, you do not want any vapor barrier because it will trap moisture regardless; it cannot dry out past the wall into damp earth and it's on the inside of the warm it cannot dry there. Basements are not the same as upper floors and need a different approach.
Skoorb is offline   Reply With Quote
The Following User Says Thank You to Skoorb For This Useful Post:
Chemist1961 (10-29-2010)
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
Vapor barrier requirement for finished basement JTK Building & Construction 13 02-05-2011 04:30 PM
Denshield and Vapour Barrier doitokay Building & Construction 5 03-17-2010 06:50 AM
Sealing a vapour barrier in garage PatS General DIY Discussions 4 10-25-2008 08:51 AM
Basement Moisture problem jimdd Remodeling 1 07-22-2008 02:48 PM
