Basement Stairs And Framing... - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By ront02769
Old 08-25-2016, 07:48 AM   #1
Rewards Points: 110
Basement stairs and framing...
Hi All,
Stairs... i would like my basement stair railing to look like the second picture (the railing will be shorter because my distance is shorter)
I have framed the knee wall beside the stringers and have fastened it to the stringer.
Once good enough, i will bolt it to the ground. BUT, before that. do i need to have 2 top plates? am i good with one?
the area in which i am going to place the newel post (currently void), i am going to use 2 pieces of 2x4s to close off that part of the frame. secure the newel post into the stringer and knee wall.
so before i drywall that section, i just want to make sure that i am okay with 1 piece of wood as my top plate and that my approach is sound
Thank you.
p.s. this framed section (bolted into the stringer) is very sturdy.
Amitabh9 is offline   Reply With Quote
Old 08-25-2016, 11:32 AM   #2
Rewards Points: 118
Re: Basement stairs and framing...
I think you should have anchored the knee wall to a full stud.
I also think you should have brought the bottom of your top plate all the way to the stringer edge and it should have a "stud" at the edge. In the "inspiration" picture the post is in front of the steps. Here is what I am talking about:
chrisb75 is offline   Reply With Quote
Old 08-25-2016, 12:28 PM   #3
Rewards Points: 1,936
Looks fine to me. Just. Did similar last week. I DID have the top plate attached to a full height stud.....but only because I wanted to end the tall will flush with the vertical cut on the stair carriage. Otherwise wouldn't have bothered. Remember that you will likely have a piece on one bye something sitting flat on the top plate making the finished surface to attach your balusters to. Ron
chrisb75 likes this.
ront02769 is offline   Reply With Quote
Old 08-25-2016, 01:19 PM   #4
Rewards Points: 110
so to confirm, do i need two diagonal pieces are wood?
i see the full stud - i can work that in
as for the end of the stringer, yes, agree, i need to build that. i may simple rebuild the entire thing. who knows.
just want to know if what i have works, or NO.
Old 08-25-2016, 01:23 PM   #5
Rewards Points: 118
Define works? Can you attach drywall to it? I don't see why not just not sure how you will finish the end of the knee wall?
Old 08-25-2016, 01:27 PM   #6
Rewards Points: 110
ok, i will rebuild it
Old 08-25-2016, 06:15 PM   #7
Registered User
Rewards Points: 526
I always added a header waste piece, sitting on the mud sill (like a header) and between the last and next stud to bolt the post to. Laying the top plate (single is fine) on the tread nosing and marking/cutting to long (wild) end of all studs gives room for side trim on the bottom sill of finish rake piece.
Gary
Old 08-25-2016, 08:03 PM   #8
Rewards Points: 1,036
I have always built my stairs with this 2x4 mud sill at the bottom. to me it makes sense but i cant really remember if its required by code and i am to lazy to look it up right now.
Mingledtrash is offline   Reply With Quote
Old 08-25-2016, 08:14 PM   #9
Not sure who said to rebuild. It is fine as it is.....given that it appears that what is there has been ther for a while...and you are onlyd reworking the open side with a knee wall. True you need to add one more stud to ithe bottom end.....which is easily done....stand a two bye up down the, mark the angle,
Cut it and nail it in.....giving you a flush vertical surface at the bottom to butt your Newell post to. And the second diagonal piece would simply be a finish board that would provide a nice surface for the balusters to attach to....you can see it as the brown thing in your first picture. Ron
Questions about framing in stairs to basement motoriderx7x Building & Construction 2 02-02-2016 07:49 AM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Framing Basement Stairs short1 Building & Construction 14 08-08-2012 12:15 AM
Basement framing around stairs teddosan Carpentry 15 01-29-2012 03:02 PM
Basement Stair Framing clemson726 Building & Construction 4 07-26-2010 05:09 PM
