Basement Staircase Code - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-08-2009, 07:47 PM   #16
I have gas!
Clutchcargo's Avatar
Rewards Points: 2,010
Originally Posted by thekctermite View Post
Uh-oh. You wouldn't like what I'd tell you.
I figured as much. I'm going to give it a shot anyway.
My wife came up with another solution, which is to cantilever the floor over the stairs slightly but maintain a 38" headspace for the stairway. Less elegant but will satisfy all the requirements. That way we could maintain an 8'x11' 2nd floor bedroom space.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 02-08-2009, 08:37 PM   #17
Registered User
Termite's Avatar
It never hurts to ask! It is sure worth a try.
Old 02-09-2009, 12:28 AM   #18
Commercial/rental code inspection is usually more stringent, from what I've heard.
It might be possible that rebuilding what's existing could be "grandfather'ed-in" (depending of the local politics, and what blueprints have been registeredwith the city), but it's better to check first and make sure.
Building it to code will probably save some sleepless night later on, and keep the resale value.
Stillwerkin is offline   Reply With Quote
Old 06-30-2009, 08:55 AM   #19
Originally Posted by Clutchcargo View Post
Still haven't figured this one out yet. I've revamped my plans for a basement step rise of 7.75" and tread of 9". Massachusetts code rise<=8 1/4" and tread>=9".
Bah....
My stairs to the great room need a rise of 51" = 7 5/16" each
That would be 7 steps 70" long
I was hoping to go to 8.25" rise but I only get to 49.5" in 6 steps
I'd need to go to 8.5" for 6 steps
I did plan for 7 steps...so I guess I go with 7
Old 11-12-2009, 05:58 PM   #20
These will be directly below the main staircase. The new basement staircase is 5 treads down and then your on a landing and then another 5 treads down to get to the basement floor for a total of 11 steps. The top 5 steps will be to code however, the bottom 5 steps get squeezed to 32.5" because the foundation is thicker than the stud wall. The new staircase would be a huge improvement over the current staircase which have treads anywhere between 7" and 6.75", rise of 8.75", and a lower width of 32.5". The only way I can make the basement staircase code is to increase the main staircase to 44" wide which takes a lot out of an already small bedroom.
Is there ever any leniency by the building department?
Edit: I'll never have the minimum head clearance as well the basement ceiling height is only 78".
Had you ever considered using adjustable stair brackets? They work well in this situation.
Deckman100 is offline   Reply With Quote
Old 11-12-2009, 10:06 PM   #21
I don't know about there but around here if you have 1 old board in there somewhere, its not new build. All you need is one
joan518 is offline   Reply With Quote
Code for basement ceiling height RDS Building & Construction 3 04-22-2008 10:46 AM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Code for Outlet Placement in Basement redbandit Electrical 5 01-02-2008 10:13 AM
Finishing basement - electrical code ??? normwannabe Electrical 1 01-23-2006 07:48 PM
