Basement Insulation - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 09-07-2017, 07:45 PM   #16
retired framer
Rewards Points: 15,732
Re: Basement Insulation
We don't want wood touching concrete. After that it is all about how much you want to chase it around for perfection.
Old 09-08-2017, 04:48 AM   #17
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,710
If it is mold, and it's locked inside the walls, it won't come out to get you.
Seal off the hole you made and deal with it later if the budget is not present now.
Although, looking at wall paneling may be scarier than mold. I had it in my basement......oh, the horror.....ha.....
123pugsy is offline   Reply With Quote
Tags
basement , insulation
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 04:42 PM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 05:44 PM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
basement insulation advise needed bmartin5150 Building & Construction 1 04-27-2009 04:56 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
