Basement French Drain - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2014, 08:35 PM   #1
Rewards Points: 97
When we build a house with a basement my boss installs the French drain so that it sits directly on the footing on the outside of the basement wall. No slope. Flat and level around the footing.
Actually I have only done one with him so far but we just started two more recently. I'm sure these will be done the same way.
Anybody else leave their French drains level?
DBoone is offline   Reply With Quote
Old 07-22-2014, 09:00 PM   #2
Civil Engineer
Rewards Points: 5,246
These are more properly called perimeter drains. There are two versions of a French drain, one named after Mr. French, and the other apparently refers to a type of drain used in France. Or so I am told. In any case, it is very common to lay the tile flat in a perimeter drain. The water will move from higher elevation to lower elevation, which is presumably a sump pit, or there is a drain which connects to the street in one corner, which collects all the groundwater from the four sides of the house.
Basement drain Ms.Bee Plumbing 1 05-19-2013 02:45 PM
Water backup into basement floor drain after jetting lateral and sanitary sewer sm2327 Plumbing 4 04-01-2013 01:18 PM
Adding a basement floor drain for A/C Condensor SuzieSawzall Plumbing 9 03-28-2011 08:51 AM
french drain waterproofing basement windy1 Building & Construction 6 10-21-2010 06:33 AM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
