Basement Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-30-2010, 08:40 AM   #1
rmc
basement floor
I had to rip up a vapor barrier that was tacked down with 1 1/2 nails. I removed the tacks and want to fill the holes. I was going to use hydraulic cement, but was wondering if i could use the concrete filler caulk to fill the holes then cover with the cement. I just want to make sure that i completely fill the holes.
rmc is offline   Reply With Quote
Old 07-31-2010, 04:44 PM   #2
Registered User
Rewards Points: 526
Either, or.
Be safe, Gary
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
Leveling Basement Floor Rigid Foam mdenis Building & Construction 6 09-07-2009 05:55 PM
Paint(?) on basement floor dissolves with water Jaybone Painting 3 08-26-2008 12:51 AM
Basement Floor Finishing, Advise Needed dbbyleo Flooring 5 04-25-2008 12:32 PM
Basement floor reno D.RED Flooring 1 06-21-2006 03:20 PM
