Thread Tools | Display Modes |
#1 |
Rewards Points: 6
![]() basement door to back yard
I have a 135 year old house & would like to put a door from the basement to the back yard.
Concrete block walls. Is it knock out blocks to be able to install support post to hold floor joists & or back sill plate. Remove blocks for door size. Install proper door jams. Install door. Prior to that, dig outside to proper depth. Create support foundation for outside opening & steps. Tie into weeping tile for a drain. I have listed the basic steps. Is there other steps or ideas that anyone else has??? Thank you for any help. thumpp |
Sponsored Links | |||
Advertisement |
#2 |
Rewards Points: 42
Don't know where you live but have you considered something like this?
http://www.bilco.com/Foundations/Sto...Basement-Doors |
The Following User Says Thank You to Larry K. For This Useful Post: |
thumpp (03-09-2015)
Advertisement |
#3 |
Rewards Points: 2,600
a piece of Lintel is probably needed?
just add some joist support inside the basement before knocking block out. is the door height same as the block height now? |
The Following User Says Thank You to concrete_joe For This Useful Post: |
thumpp (03-09-2015)
Advertisement |
#4 |
Rewards Points: 264
I would put a roof over it and grade the area for draining away from the house. The drain you're planning may not handle one worst storm and flood the basement. Also light overhead.
The Following User Says Thank You to carpdad For This Useful Post: |
thumpp (03-09-2015)
#5 |
Rewards Points: 6
![]() Thanks
Thanks for the advice!!!
#6 |
Rewards Points: 6
![]() Thanks
Advertisement |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Water leak in back yard | WyrTwister | Plumbing | 34 | 11-29-2014 07:33 AM |
Tips on laying out master plan for large back yard | butterkups | Gardening Forum | 8 | 03-17-2013 11:46 AM |
Standing Water in Back Yard | 7 VII 7 | Landscaping & Lawn Care | 4 | 03-13-2013 01:52 PM |
Why fill the basement back in with dirt? | nateshirk | Building & Construction | 18 | 04-19-2011 09:18 PM |
My back yard needs help! | JJ Young | Landscaping & Lawn Care | 2 | 03-12-2010 01:53 PM |
