Basement Bathroom Tub & Subfloor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2010, 11:31 PM   #1
Basement bathroom tub & subfloor
Hi,
I'm renovating our basement bathroom and it's currently down to concrete floor and studs (tub, toilet all removed). The old tub was on a subfloor that covered the entire washroom. When I install the new tub, would it be better to just install it onto concrete directly, and add subfloor over remaining washroom floor (around tub), but underneath toilet.
Thanks.
jayblue is offline   Reply With Quote
Old 01-08-2010, 07:15 AM   #2
Does anyone have any advice on this?
Old 01-08-2010, 07:48 AM   #3
An old Tradesmen
Rewards Points: 9,860
Your duplicate threads in the other forums have been removed.
Please don't post duplicate threads across the forums.
When someone has an answer, they will respond if they wish to.
Thank you for your cooperation.
Old 01-08-2010, 10:27 AM   #4
RDS
Rewards Points: 150
I'd like to help out a fellow Canadian (nice to see it called a "washroom") but I can't think of a reason it would be better one way over the other.
If you put the tub right on the concrete but put subfloor (sleepers and plywood, I assume) in the rest of the room, you'd have less of a step up to get into the tub. Which you might want if, e.g., you're bathing kids in there or your knees are bad.
If you put the tub up on a subfloor you'd have the option to add some insulation under it, maybe help keep the water warm longer.
RDS is offline   Reply With Quote
Basement bathroom exhaust fan install krusty HVAC 5 09-15-2009 07:41 PM
Sealing a bathroom subfloor? CollegeGirl Flooring 4 07-21-2009 03:50 PM
Basement Reno - Laundry, Bathroom mostr Building & Construction 2 03-02-2009 09:50 PM
Venting basement bathroom fixtures ccathy247 Plumbing 1 11-01-2008 03:44 PM
Removing damaged bathroom subfloor icandoitmyself Flooring 3 10-23-2007 08:50 AM
