Basement Bathroom Size? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-28-2010, 11:07 AM   #1
Rewards Points: 736
Basement bathroom size?
What is are good dimensions for a bathroom in the basement? would love to have it as complete as possible with a shower and such.... right now they current one is 6x6ft which is big enough for a small vanity and a toilet..... but want to add a shower to make it more usable.... any ideas on what you've seen or what would be a good size to expand it to?
BlueBSH is offline   Reply With Quote
Old 06-28-2010, 08:03 PM   #2
5' x 7' is normally considered the minimum size for a bathroom. This allows 30" for tub/shower, 24" for vanity, and 30" for toilet = 84" along the 7' wall, with the entry door swinging away from the fixtures toward the opposite wall.
The vanity can be a less in width (like 20") to allow for more clearance for the other fixtures. Also, you can rearrange the fixtures on different walls in the bathroom. NKBA has some more generous guidelines:
http://www.margielittle.com/docs/bathroom.htm
Here are some IRC requirements:
http://www.hgtv.com/home-improvement...out/index.html
As always, your local codes apply.
fortop is offline   Reply With Quote
DRIcore in basement, tile in bathroom windsorguy13 Flooring 5 03-09-2010 03:46 PM
Basement Bathroom Insulatation/VB? mfleming Building & Construction 1 05-06-2009 04:27 PM
Effluent pump for basement bathroom Christopher C Plumbing 7 04-23-2009 09:35 AM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 12:17 AM
Basement Reno - Laundry, Bathroom mostr Building & Construction 2 03-02-2009 09:50 PM
