Barrier Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-24-2010, 11:14 AM   #1
barrier insulation
can i put barrier insulation on inside exterior walls before sheetrock
gordon22 is offline   Reply With Quote
Old 07-24-2010, 01:03 PM   #2
Pro
Nostco's Avatar
Poorly worded question.
Yes, insulation can go on the inside of exterior walls before the drywall. You need a vapour barrier, unless it's sprayed/kraft, which already has vb (some).
The vapour barrier goes on the warm side.
Insulation can be outside/inside. In most applications, it's inside.
Rewording your question/providing more specifics gets you a better answer. Hope that helps
Nostco is offline   Reply With Quote
Old 07-24-2010, 01:28 PM   #3
Registered User
Rewards Points: 526
If you mean a vapor barrier, perhaps. Only if you live in a location that requires one: http://www.buildingscience.com/docum...ecommendations
Most of the U.S. does not require a vapor barrier when a vapor retarder will work: http://www.ecohomemagazine.com/energ...gy-claims.aspx
Difference between a vapor barrier and a retarder: http://www.energysavers.gov/your_hom.../mytopic=11810
Be safe, Gary
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Basement insulation / vapor barrier questions deepstuff Building & Construction 16 02-09-2012 09:11 AM
Insulation vapor barrier DIYminer Remodeling 1 01-04-2010 02:38 PM
Radiant barrier with faced insulation? luci468 Building & Construction 1 07-18-2009 03:49 PM
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 08:56 AM
