Back Buttering Tiles - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-29-2020, 06:37 PM   #1
Rewards Points: 338
Back buttering tiles
Installing 8x24 ceramic wall tiles in the shower. I have been back buttering, I feel so rushed though, especially since it's only me doing it. I'm guessing it's not okay to do them all ahead of time and let them dry out?
Jamesonc is offline   Reply With Quote
Old 06-29-2020, 06:49 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,360
Re: Back buttering tiles
You can backbutter the tiles, but you still need thinset on the walls. Sometimes backbuttering can cause the tiles to not sit well, so use it sparingly unless you feel adhesion problems with just the thinset.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 06-29-2020, 08:14 PM   #3
Rewards Points: 338
Thank you for responding. I am putting thinset on the walls. From my understanding, isn't back buttering basically just filling in all the grooves and what not in the back to make it flat? If so, I thought it would be great to just back butter all of those first, sparingly.
Old 06-30-2020, 08:44 AM   #4
Rewards Points: 12
Yes, you should backbutter the tiles, and yes, it should be done basically just before you place the tile. You don't want either the thinset on the wall or the backbuttered thinset to dry out, or the bond they form won't be as good as if they're both wet.
huesmann is offline   Reply With Quote
The Following User Says Thank You to huesmann For This Useful Post:
Jamesonc (06-30-2020)
Tags
back buttering , shower , tile
