Attic Ventilation - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-22-2009, 08:59 PM   #16
Are you sure with the perforated soffit there isn't venting?
Have you been up on a ladder w/flashlight & checked?
Old 07-22-2009, 10:01 PM   #17
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 586
I need to check better, but I did check one area and was able to feel that there is plywood or some other hard surface blocking the soffit material. The way my overhangs are built I don't have good access to them from the attic as I can't stick my head in enough to see, there is about 1-2 inches gap between the top and the corner of the ceiling/wall, then the overhang is lower then the ceiling. I put my arm in with a hammer hoping I would feel the hammer just bounce off the soffit, but it hit a hard wood surface that seemed flat like plywood as I moved the hammer around.
Now what I am hoping is that there are at least some areas where there are vents. So maybe I'm safe, but I'm probably better off just opening it up from outside and cutting I guess. This is an old house so I'm guessing at some point it looked like this and they just added the metal soffit material over.
Attic Ventilation in 1928 Bungalow stephensandlin Roofing/Siding 1 07-09-2009 11:16 PM
attic ventilation lou1968 Roofing/Siding 5 05-31-2009 09:33 PM
attic ventilation chutes question MadisonMan Building & Construction 1 11-20-2008 10:52 PM
Attic Ventilation stouto Roofing/Siding 3 11-11-2008 03:04 PM
